Print Button not working...
1 ANTWORT 1
Nachricht 1 von 2
283 Aufrufe, 1 Antwort
I know this has been posted on before.  All workarounds have only worked for a brief period of time.
Has AUTODESK or Microsoft provided any information on a fix?
This is serious software, and it can't be some band aid fix to an ENORMOUS GLITCH in the use of it.
How do we get AUTODESK to respond to this issue?
1 ANTWORT 1
Nachricht 2 von 2
andrea.kikuchi
als Antwort auf: Anonymous
Hi there, are you getting an error or is nothing happening when you use the print function? If you are getting the unable to connect error, there are fixes now available from Microsoft here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
