Hello there,
I'm having a big problem with PDF printing. Basically, if I print as PDF with my typical Revit legends for repeating information it rasterizes everything in the sheet, but if I delete the legend from the sheet, the plan comes out as vector. Everything in the legend is text, component or detail lines, so it should be able the export as vector. See below both examples. I've always used legends on my sheets for repetitive information and this is the first time this happens. Please help. I'm using Revit 2017.2
Gelöst! Gehe zur Lösung
Gelöst von Archigrafix_Norge. Gehe zur Lösung
Maybe slipped some images in there somewhere by accident?
I would do some troubleshooting to see if I could pinpoint the problem:
-Make sure that you have vector processing selected each time (does Revit give warning that it will switch to raster processing?)
-Create the sheet without the legends.
-Print it out as vector to see if it does.
-Add a legend and print it out again.
-Repeat this process to see if you can find which one is the problem.
-Check that legend for graphics.
-Delete and recreate the problematic legend.
-Check if you have the same issues with other projects.
-Check if you have the same issues with a new project.
Louis
Please mention Revit version, especially when uploading Revit files.
Try setting the visual style of your legend to hidden style or wireframe in case they are not set like that. I wonder if the style is set as something else, for instance shaded.
Luis Santos
archi systems as
Besides the tip from Marc.
I gave some advice troubleshooting tips in my previous post. Have you tried those? What were the outcomes?
Louis
