Prevent drag edit in family
11 ANTWORTEN 11
Nachricht 1 von 12
cbt990
563 Aufrufe, 11 Antworten
I made a family that is supposed to be only 18" or 20" square. When I create the size as an instance parameter, I can toggle between the two but also drag it to any other size. When I change the size to a type parameter, the family no longer changes size when I change the type. I'm kind of confused about how to get the intended functionality.
Revit is amazing
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: cbt990
Seems fine here.
Nachricht 3 von 12
Did you edit the type in the project and change the parameter under type properties?
Nachricht 4 von 12
cbt990
als Antwort auf: ToanDN
I changed the type in the type selector:
and nothing happens.
When I change the parameter value, then it changes:
Isn't there a way to build a title block family with only selectable sizes as different types?
Revit is amazing
Nachricht 5 von 12
You need to change the Size parameter value, not just the Type name.
18" is 1'-6" not 1'-8".
Nachricht 6 von 12
cbt990
It's because the value isn't changing when I change the type.
Revit is amazing
Nachricht 7 von 12
cbt990
So the type name is essentially unnecessary?
Revit is amazing
Nachricht 8 von 12
The type name is good to be descriptive and should match the Size parameter otherwise it is backfiring.
Nachricht 9 von 12
cbt990
They don't seem to change correspondingly, is the issue. I can update the parameter to the wrong value in the wrong type. How do I prevent that?
Revit is amazing
Nachricht 10 von 12
You need to make two types just like you're doing.  When you toggle the Type, you need to accept it.  In other words, and "swap" isn't made instantaneously. You need to follow through.
...Have you loaded and placed this Family in a Project yet?  Once you do, you pick the Type via the Type Selector just like you do with any Family.  The Type Properties are irrelevant to this operation.
Nachricht 11 von 12
How do you prevent entering the wrong value for the parameter?  Bruh, you just have to pay attention when doing it.
Nachricht 12 von 12
mhiserZFHXS
@cbt990You really need to look into some basics of family creation, specifically how instance and type parameters work. There are plenty of resources on YouTube that should straighten out your issues pretty quickly. I commend you for taking the dive.
