Prevent Base Constraint from resetting to view level
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
2208 Aufrufe, 8 Antworten
I was wondering, Is there a way when creating a wall to prevent a Base constraint and or Top constraint from resetting when you create the next wall or hit escape?
Now everytime I've created a wall and want to create the next one it resets the Base constraint to the view level and the Top constraint to the next building story.
Awaiting your reply and thanks in advance.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
right click on the wall and select create similar. It should create the wall with the same properties.
Nachricht 3 von 9
Thank you for your fast reply. I tried your solution but it keeps resetting the Base and Top constraint.
Nachricht 4 von 9
strange, I added wall in two different ways it always keeps my settings.
Nachricht 5 von 9
I attached a Gif of what happens on my screen. My properties are on the right, you can see them reset.
Nachricht 6 von 9
you are right. It resets the level settings but not the offset settings from the levels.
Nachricht 7 von 9
luna.ye
Hi bakker,
Welcome to Autodesk forum!
When creating wall on the floor plan, the plan should be one of the constraint. So if you want to keep the constraint setting, please try to edit the Heigth or Depth on the Options bar as below
And if you want to edit the Base&Top Constraint, please go the 3D view to set the level and the constraint
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
Nachricht 8 von 9
ccastelein
Wish that worked, but as soon as i escape... it resets all... :enttäuschtes_Gesicht:   (revit 2021)
Nachricht 9 von 9
cmagee6U2NA
als Antwort auf: ccastelein
Has anyone found a solution?
