Predefined Annotation Box in Drawing
4 ANTWORTEN 4
Nachricht 1 von 5
vkulikajevas
433 Aufrufe, 4 Antworten
I defined the Scope of my view, but when I place it in the drawing, it shows the SECTION LINES way beyond the scope box. Is there a way to make it understand automatically not to show these stray sections? Predefining annotation Box maybe?
4 ANTWORTEN 4
Nachricht 2 von 5
luna.ye
als Antwort auf: vkulikajevas
Hi @vkulikajevas,
I'm not sure about the issue in your screenshots, so they're plans or section view? The section tag should be visible when crop region and view range intersect. Is similar to: Levels and Grid Lines Visible Outside Crop Region?
Or you can provide more details? Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
Nachricht 3 von 5
vkulikajevas
als Antwort auf: luna.ye
Hello, @luna.ye thank you for your reply. This section detail happens in all plans. When section is close to the scope box, it show it. I was wondering is there a way to automatically trim it.
Nachricht 4 von 5
Ilic.Andrej
Check "annotation crop".
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 5 von 5
vkulikajevas
als Antwort auf: Ilic.Andrej
@Ilic.Andrej, yes. Annotation crop for every view does the same as hiding each section. It is not controlled globally, that is the problem. Or is it?
