Hi everyone
I am trying to model a stair with precast threads/step. I tried to draw it using the stair tool and with both type Precast and monolithic from Revit families and also tried by sketch but it somehow looks the same in precast and monolithic stair all in one piece connected from bottom to top and when I select it it says monolithic run!!! except for the key joint at the top end there doesn't seem to be a difference and I cannot select the individual steps
I was expecting that I get several precast element. I tried to make it parts using the parts tool similar to what I would do with walls and floors but that option does not seem to be available for stairs!!
How can I model a precast stair with several elements or parts not one whole run in one piece?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
Everyone tend to avoid such questions
especially when it comes to stairs... No one likes them and everyone believes that Autodesk Revit suck when it comes to the Stairs tool
So your options are...
PS: if someone asks you...Revit's stairs tool is amazing and as complete as it can get; what is not in made available in the tool itself; it developers placed a back door to get to it
That is exactly what I need...big THANK YOU
I knew there is a way but it wasn't obvious...when I tried to argue about it in class everyone kept telling me no it's not possible and that I have to take the path you mentioned first! Now we'll see who's going to be laughing when I get to class
i would love to learn about those adaptive stairs you mention.I checked he chapter we will be doing by the end of this semester it's just a few pages with nothing more than triangles and squares. No real structures there. Any advice I can get from you on that?
