Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
precast stair-issues
seamea12
Message 1 of 16
seamea12
On the left side it's my precast stair model .On the right it's what I want to achieve . I have problems :1) how to model run with ending notch higher to landing ,2)how to model start run to get shape like on the right pic,3)first riser of the run should  be  different to the rest ?
Accepted solutions (3)
Replies (15)
Message 2 of 16
Put it on a pedestal.
Message 3 of 16
Lachlan-JWP
The base of the stair should be offset from the level by 15.25cm, model a floor that thick to act as the "first" riser, offset the top of the stair by 7cm. That should be all you need to do.
Message 4 of 16
seamea12
Thank you very much.First advices work but when I want to offset the top of the stair by 7 cm it dosn't work. May explain a bit more , please?
Message 5 of 16
seamea12
Thank you but I still ought to have my upper notch 7 cm higher to my landing and that's my problem/
Message 7 of 16
seamea12
Thank you for your advice .But using these properties I can't get what I want  i.e. I want to have my upper level of my notch higher 5 cm to my landing.notch.JPG
Message 8 of 16
Yah, that's going to be another element similar to the pedestal.  Model In-Place as per the solutions cited in that AKN Article I linked you to above.
Message 9 of 16
seamea12
Thank you I 'll try as you suggested
Message 10 of 16
Lachlan-JWP
Have a look at the attached project. I've got most of everything that you need, just can't get the underside of the landing the stair to join cleanly. It can be cleaned up with a filled region or the linework tool if required.
Message 11 of 16
Message 12 of 16
Lachlan-JWP
I thought they wanted this area filled in?
Message 13 of 16
Oh, I misunderstood. My bad.  Sorry about that, @Lachlan-JWP.  I see now that you were providing something for the OP.  Nice work, BTW.
I'll bump my post.
Message 14 of 16
seamea12
Thank you very much for your advice. Almost everything is ok excluding that small underside of the landing which you mentioned. You are right it can be solved in 2d view only . I am afraid it can't be solved by using precast stair . Finally I decided to follow by Barthbradley's suggestion and modeled it by model in-place. Any way Thank you very muchSTAIRS-MODEL -IN PLACE.JPG
Message 15 of 16
seamea12
Thank you again !. I ve done it as you suggested by model in-pace . It works perfectly and very simply for me!
Message 16 of 16
Brad_Chan1
hi may i know how to remove this under part in precast stair?
