Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Actually I could not understand what is the issue unless I have repeated it step by step as you have mentioned ![]()
IF you need to open a certain Revit file that has been saved before , you have to go to the path of saving and select the file that need to be opened.
You can not type a file name by yourself.
I wish I have understood you well.
Hello @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! ![]()
If you are trying to open - Syracuse-Suites-Grids.rvt do you know the location/ path where you have saved it?
If so, you can open it from your windows explorer or try these options HERE
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
