Message 1 of 14
Hello All,
I need some help with this "Pole Barn" exterior. Draw it like you build it! I'm using REVIT LT 2018.1
1. I made a wall sweep for my siding and however it covers my window but cuts around my sweep trim. I unchecked the window brick mould, extended my window depth and added my own trim( sweep). The siding is offset out - 1 1/2" for the 2x4 purlins. Have my boxes checked for "Cuts Wall" & Cut by Insert".
2. For the purlins I use structural framing. Is this the best strategy?
3. Any advice on the gable wall sweep? Is there a screencast for one like this?
Thanks again as always!
