Portable PC: Revit 2021 requirements
11 ANTWORTEN 11
Nachricht 1 von 12
XXalessio.amodioXX
1988 Aufrufe, 11 Antworten
Hi all,
As title I would like to know wich kind of portable PC can be suitable to run properly Revit 2021, related to my needs.
I want to have access to our model even during my holiday because of my job position.
I am extremily manical in keeping  our model low sized.
Usually for small medium sized models I keep it below 25MB, whilst large sized project (e.g. 10-15 Storey building) below 250MB.
I do not perform any kind of rendering, but I do coordinate several discipline (Linked models)
I would prefer an ASUS beacuse I used it during my study career, but whatsover suggestion is highly appreciated.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: XXalessio.amodioXX
Nachricht 3 von 12
hmunsell
Middle of last year I got a Dell G7 15 - 7590 and it has been working really well for my Revit models, Inventor, AutoCAD, Navisworks, etc.... (as well as some higher end gaming :zwinkerndes_Gesicht:).   I don't think that model is available any more, but here are the specs of what I got. There is plenty of room for improvements if you can afford it. this was the best i cold afford at the time.
  • 9th Generation Intel(R) Core(TM) i7-9750H (12MB Cache, up to 4.5 GHz, 6 cores)
  • NVIDIA(R) GeForce RTX(TM) 2080 8GB GDDR6 with Max-Q Design
  • 2 x 512GB M.2 PCIe NVMe Solid State Drives
  • 32GB (2x16GB) DDR4, 2666MHz
  • 15.6 inch FHD (1920 x 1080) IPS 144Hz Display
  • Killer 1550 802.11ac 2x2 WiFi and Bluetooth 5.0
  • Windows 10 Pro (64bit) English
Howard Munsell
Nachricht 4 von 12
XXalessio.amodioXX
als Antwort auf: hmunsell
The PC you suggest me is super awesome, but quite expensive too. Cosidering the fact I will be using it just few days in year (Usually I prefer work in office) I do not think is a good ROI.
PS For gaming I prefer XboX
Nachricht 5 von 12
XXalessio.amodioXX
als Antwort auf: barthbradley
Hi.
It is a very detiled article.
For the needs described above, what do you think it could be acceptble Portable PC.
I am just looking for suggestion from expertises as you.
Nachricht 6 von 12
ennujozlagam
maybe this one?txs
https://laptopstudy.com/best-laptop-for-revit/
Nachricht 7 von 12
hmunsell
Well you didn't say only a few times a year... LOL... :sich_vor_Lachen_auf_dem_Boden_winden:. yes it was quite pricy.... if I remember correct it ran a hair over 2k. I purchased it as my primary Home PC. but i use it for my side business, for work and for software testing. so it was worth it :strahlendes_Gesicht_mit_lächelnden_Augen:.
You can skinny down the price a little bit by probably $500 +/-:
  • only getting a 4gb video card (vs the 8gb)
  • 1 x 512 SSD drive
  • 16gb memory (vs 32gb)
you'll take a little hit on performance, but should still be usable for what it sounds like your using for.  somthing else to remember is if you only using this a couple times a year, it is going to become out of date/spec really quick. spending more on it now will hopefully mean you wont have to upgrade again for a longer time.
Howard Munsell
Nachricht 8 von 12
Value: Balanced price and performance
Operating System ¹64-bit Microsoft® Windows® 10. See Autodesk's Product Support Lifecycle for support information.
CPU TypeSingle- or Multi-Core Intel®, Xeon®, or i-Series processor or AMD® equivalent with SSE2 technology. Highest affordable CPU speed rating recommended.
Autodesk® Revit® software products use multiple cores for many tasks.
Memory16 GB RAM
Usually sufficient for a typical editing session for a single model up to approximately 300 MB on disk. This estimate is based on internal testing and customer reports. Individual models will vary in their use of computer resources and performance characteristics.
Models created in previous versions of Revit software products may require more available memory for the one-time upgrade process.
Video Display ResolutionsMinimum:
1680 x 1050 with true color
Maximum:
Ultra-High (4k) Definition Monitor
Video AdapterDirectX 11 capable graphics card with Shader Model 5 and a minimum of 4GB of video memory.
Disk Space30 GB free disk space
MediaDownload or installation from DVD9 or USB key
Pointing DeviceMS-Mouse or 3Dconnexion® compliant device
.NET Framework.NET Framework Version 4.8 or later.
BrowserMicrosoft Internet Explorer 10 or higher
ConnectivityInternet connection for license registration and prerequisite component download
i think its probably helps u .....if you need more information related to this topic
Kindly check in
https://knowledge.autodesk.com/support/system-requirements
Nachricht 9 von 12
HVAC-Novice
For hardware, always at least double of what the vendors says the minimum is.
But did you think about how you handle the Revit license and the project file transfer? if you use it on a laptop, you need to have Revit installed (and license) and move the project file. if other team member use the same central file, that will be a problem.
An alternative would be to keep that on your powerful office PC and to remote into that from your laptop. that way the rest of the team can work the same way, and the laptop doesn't need to be so powerful.
My office PC has 32GB and all the Revit needs regarding CPU, GPU etc. But my home PC I remote in from is older with 16GB and iGPU and it works fine.
I also would make sure the laptop is capable to run an external 4K display (mostly via USB-C and hub nowadays) and isn't just HD. Working on a 15" display must be painful outside of tiny edits to the model.
Revit version: R2025.4
Nachricht 10 von 12
XXalessio.amodioXX
als Antwort auf: HVAC-Novice
Thanks for your answer.
Our licence is ID Name based, thus just internet connection is in need.
The alternative is not handy becouse we want to keep working in Cloud.
To solve central problem issue I usually work with discipline linked file, so not big deal. Usually we subcontract all discpilines.
I d prefer using double monitor. This is just solution for few days per year because I d rather work from office.
I think this model might be a good solution:
ASUS TUF Gaming F15 FX506LI-HN109T
Nachricht 11 von 12
XXalessio.amodioXX
I forgot to convert USD to EUR. Now it does not seem so pricey!
EDIT Yes it would not be Pimary PC. I would be in need of it if urgent work must be prepared even for weekends or holidays.
Nachricht 12 von 12
hmunsell
LOL... ya that could make a difference :Gesicht_mit_Freudentränen:
Howard Munsell
