Polyline Based Families / String Together Line Based Families
cmerloEXWAB
cmerloEXWAB
Is it possible to either generate a family that follows a polyline or to string together multiple Line based Families that autojoin? I'd Like to have a countertop family that is pretty much All Purpose but you end up with seams for inside turns and gaps for outside turns. I've attached photos and a copy of the family I made as a trial for this.
Tom_Kunsman
Not aware of any way of having separate families "autojoin" like you are suggesting. Walls can for sure.
You could consider some visibility parameters with this to control when a infill/corner needs to happen. Although I think such a family might have a lot of options that might make it difficult to use.
handjonathan
Hi @cmerloEXWAB
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @Tom_Kunsman @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Use railing, wall, or in place sweep.
