Could anybody help me to create the revit mass from this 3d Solid model. Its very urgent. Kindly help me.
Edited by request
Discussion_Admin
Gelöst! Gehe zur Lösung
Gelöst von shefypattambi. Gehe zur Lösung
You would have saved my time downloading it if you mentioned that it's Revit 2017. I have Revit 2016 so if you have older version I can try to help.
I didn't know what you have is a dwg file. Here are the steps:
Open a new project, then go to "mass in place", accept the name then go to Insert > Import Cad
Choose your dwg file then click finish mass. Then you can use the elements by face to create your solid geometry.
I got the solution by switch off the turbo smooth mode in the 3d max model and exported the file into AutoCAD. By doing like this we can avoid the unnecessary polygonal mesh face from the model.
