ı have circular spaces in my project, in revit it looks smooth round without edges, but when ı throw it to the lumıon to render, te polygon numbers decrease and look diagonal. Is there a solution?
I put in the appendix as it appears in both revit and lumıon. Not only here, ıt also educes the softness of the slopes.
Gelöst! Gehe zur Lösung
Gelöst von goulnazarianh. Gehe zur Lösung
Hello
Have you tried increasing the surface smoothing during the export to have a nice round corners in Lumion?Try to increase the gauge all the way in.
I tried what you said and it was fixed when I export and do it. but is there any way to increase the polygon when using livesync . thanks a lot.
If you click on the Settings and again increase the Surface Smoothing it will do the work.
Here's a screenshot for that. Good Luck!Drag the gauge till the end.
yes I could not see the setting in front of my eyes. There was an easy way, thank you very much for your help.
