PointCloud cache prevent windows login
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
aleksei.melnikov
334 Aufrufe, 1 Antwort
Hey Community!
I've got stuck with a problem during working with PointCloud files (rcs) in Revit.
While I am working Revit creates dozens of JSON files in user AppData (C:\Users\%username%\AppData\Roaming\Autodesk\RVT\2018\MUI64\18.3.1.2\MC3\Json)
For some reason, after closing Revit not all of them are being cleaned.
After consulting with IT we discovered that the amount of these files makes windows logon process extremely slow. You can stare at the login screen forever.
Have anybody else experienced such an issue?
Is there a possibility to change a storage location for these JSONs, so Windows wouldn't scan them each time you're log in?
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
Same problem here.
Maybe related to: https://forums.autodesk.com/t5/navisworks-forum/creation-of-json-files-why/td-p/8118959
I've turned off desktop analytics and will see if problem goes away.
Matthias
