Point Clouds from linked files
6 ANTWORTEN 6
Nachricht 1 von 7
869 Aufrufe, 6 Antworten
I have a linked (overlay) file "A" in my model "B". I added some point clouds files in this linked file "A".
I don't understand why but now I can see the PointClouds in my model "B".
This behaviour is different than the other kind of files. Normally when we link a file in a linked file you can't see the linked file in linked unless you set the "attached" option instead of "overlay".
Is this normal?
Thank you in advance.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Post the files. A and B.
Nachricht 3 von 7
als Antwort auf: barthbradley
Nachricht 4 von 7
Hi @barthbradley ,
I'm afraid that I am not allowed to send them.
Is it not a normal behaviour?
Nachricht 5 von 7
Maybe the Phase Mapping?  Set your View Phase Filter to "None" and see if it shows.
Nachricht 6 von 7
Are you saying the PC is in RVT A and RVT A is Linked into RVT B? If so, PC should be visible in RVT B. If you are saying PC is in RVT A and RVT A in Linked into RVT B -- and RVT A/B is Linked into RVT C -- the PC is not visible in RVT C.
Nachricht 7 von 7
Hi @barthbradley ,
Yes, the PC was linked in RVT A  and RVT A is Linked into RVT B.
Did I do something wrong? Is it not the best way to proceed?
