Hello all,
I would like to know what software I can use in order to convert a point cloud obtained from a laser scanner into a 3D model (specially for Revit)
could you give me some examples?
Thanks all.
Are you looking for an "easy button"? Unfortunately, there is no “easy button” to convert a point cloud to a complete and perfect 3D model. There is, however, solutions that makes it easier by automating the extraction of some shapes.
Yup. In most cases real-life objects have swoops and whoopdies, are not square or level or plumb, etc. You usually don't want that in the models, rather everything is idealized so drawings can be easily generated. Try creating a beam with an arbitrary twist in it...
Hello barthbradley dgorsman
what would you say it is the best software to modeling point clouds? realworks maybe¿
