Point Cloud not in the correct position
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
robertovalentino
809 Aufrufe, 10 Antworten
Hello guys; I really need some help here.
Please see the attached image
In file one, I have the point cloud, and in file 2, I have the building
The two files share the same coordinate system.
File 2 loaded in file 1 is shown in picture 1, and everything looks fine.
When file 1 is loaded in file 2, using the shared coordinate system, picture 2, as you can see, the geometry goes in the correct position while the point cloud is shifted.
I added spot coordinates in the corner to be sure they are the same, and actually, they are.
Aly clue?
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: robertovalentino
What you are saying doesn't make sense or isn't complete.  Are you inserting a Point Cloud or are you inserting an RVT containing a Point Cloud into another RVT?  If you insert a Point Cloud (e.g. RCP) into an RVT via Shared Coordinates, it only means that the origin of the PC will land on the Survey Point in the RVT.
Nachricht 3 von 11
robertovalentino
als Antwort auf: barthbradley
Dear @barthbradley
Thank you so much for reading and replying to my message.
Fortunately, my non-sense message makes a lot of sense for other users, and I learned this is a well-known Revit bug that Autodesk Technicians helped me to work out.
Thank you again!!!
Nachricht 4 von 11
What "Bug"? Tell us more and give us the solution please?
Nachricht 5 von 11
It can happen when the origin of the point cloud is very far from the point cloud itself.
Nachricht 6 von 11
RobDraw
What other users? I don't see any responding here.
Rob
Nachricht 7 von 11
Sorry for my late reply and sorry for my poor English. It is not my mother language, and I try my best.
PROBLEM:
Revit File 1 has the point cloud linked using the shared coordinate system.
As a test in the very same file, I modeled a downspout following the point cloud.
Then I loaded Revit file 1 into Revit file 2, using the same shared coordinate system.
In Revit file 2, the downspout landed in the correct position, but the point cloud was strangely shifted.
This is the problem I was trying to describe in my first message.
SOLUTION:
- I detached the point cloud from Revit file 1. saved it.
- I detached Revit file 1 from Revit file 2. Saved it
- Cleaned up my cash folder.
- Reloaded the point cloud in Revit file 1 using the shared coordinate system. Everything is OK; the downspout matches the point cloud.
- Reloaded the Revit file one into Revit file 2 using the shared coordinate system. Everything is OK now.
Conclusions:
It seems like Revit files have some kind of memory of previous attempts at linking files together, and Revit file 2 somehow forced the point cloud into the wrong position, even though it was linked through Revit file 1.
@RobDraw
I posted my question on other channels, and that's how I learned about this "Memory" effect. I was referring to that when I said "other users."
Nachricht 8 von 11
IN_GGP
As far as I know, any file in real coordinates, such as point clouds or some DWGs, can cause graphics problems in Revit. It's known that Revit doesn't like things too far from origin. At least, this is what Autodesk told a couple of years ago while trying to figure out why a point cloud suddenly "moved" from its position, even if pinned, causing a mismatching with the model (modeled using the point cloud, by the way).
Since then, unfortunately, we decided to used everything in relative coordinates. This wasnot the best workflow, but it worked. Besides, in other project we tried to used that trick of clean temp files and so on, but doesn't work always.
If any one knows any other way to do it, please, share! And an Autodesk official opinion or solution would be also appreciated.
Nachricht 9 von 11
RobDraw
als Antwort auf: IN_GGP
Unfortunately, the shared coordinates workflow is the best and only way to do it without errors, even if you don't like it.
Rob
Nachricht 10 von 11
IN_GGP
als Antwort auf: RobDraw
The point is not what I like or don't. It's that this workflow (absolute/real coordinates) fails. And even Autodesk recognized it to us a couple of years ago. I guess it is not solved, because even nowdays, we have problems with point clouds.
Nachricht 11 von 11
RobDraw
It does work. You even said it does. What's the problem now?
Rob
