Point cloud issue
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
micah
508 Aufrufe, 5 Antworten
Point cloud issue
We are using Revit 2021  and have a point cloud survey with the extension  *.rcp. I keep getting an error message that says the file is incompatible or corrupt when I try to insert this point cloud into Revit. We have redownloaded the same file as well as exported the entire new file. However, we continue to receive the same error. I have attempted to insert the point cloud using all the options Revit provides. (Center to Center & Origin to origin. & By shared coord.) We are not sure what we are doing wrong. Please find attached images & project links to get a clear idea of the issue.
Let us know how can we resolve this issue.
Revit file : https://msacloud.egnyte.com/dl/H4MxfC3lYx
*rcp file : https://msacloud.egnyte.com/dl/lGtktzbpUB
CAD file:  https://msacloud.egnyte.com/dl/zqbIacyP2V
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: micah
The RCP is 2KB, of course it doesn't work.
RCP is a point cloud project, which needs the RCS or PTS source files.
Nachricht 3 von 6
Nachricht 4 von 6
constantin.stroescu
You'll need to have the Support File folder beside the .rcp file - that Support File , usually is a huge folder...
The support folder needs to be in the same folder as the RCP file for it to be able to open correctly
https://www.ths-concepts.co.uk/rcp-point-clouds/
Constantin Stroescu
Nachricht 5 von 6
hoffmannstefano
I have visibility issue of points cloud after closing and re-opening rvt projects, how do I manage ??
Nachricht 6 von 6
RobDraw
als Antwort auf: hoffmannstefano
This thread is about another topic. Your answer should be coming in the thread that you started with the correct topic.
Rob
