Point Cloud Coordinates in Revit
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1172 Aufrufe, 2 Antworten
Hi
I'm in search for a simple workflow to have a point cloud to the correct coordinates within Revit, I've been unable to find anything helpful whilst searching the internet.
Surveying done with Trimble equipment and access available to Trimble software if needed.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Put the PC in a RVT and Link into parent RVT and set up Shared Coordinates.
Nachricht 3 von 3
SteveKStafford
If you want your point cloud and Revit to match up with survey data it is important to make sure the point cloud is generated and coordinated with the survey data first. If that isn't true then you need to treat the point cloud as the accurate "site data" and do what @barthbradley recommends.
In fact I'd do that regardless because it also allows me to manage the point cloud visibility/loading via individual worksets which can be closed/opened. In the past I've manage an entire building's point cloud floor by floor. I could only open one floor's point cloud in views for that floor.
Steve Stafford
