Plus/minus before 0.00
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
JavierCarreraArias
7165 Aufrufe, 4 Antworten
I have problems getting to work the conditional formatting for the spot elevations and coordinates.  Our goal is to get the following correct way in Europe of showing numerals:  -3,00/ ±0,00 /+3,00.  I have succeeded doing that in Level Heads with a preffix and conditional format:
PARAMETER PREFIX:  if(Elevation = 0 mm, "±", if(Elevation > 0 mm, "+", ""))
But in Spot Elevations I can't find the way.
I could use a hand here. Thanks
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: JavierCarreraArias
You have to create a new type with the (±) prefix and use it for all 0.00 spot elevations.  It is not fun to keep track when the elevations change, though.
Nachricht 3 von 5
You can set the plus/minus symbol as the a Prefix or Suffix Elevation Indicator under Spot Elevation Type Parameters.
...**** you Toan! Where did you come from?!
Nachricht 4 von 5
als Antwort auf: barthbradley
Why did the forum replace "Love" with ****?  Such unnecessary censorship lol
Nachricht 5 von 5
als Antwort auf: ToanDN
Just to be clear, @ToanDN: the word that was censored was "d a m n", not ****!
As Admiral David Farragut famously shouted at the Battle of Mobile Bay during the Civil War: "**** THE TORPEDOES FULL SPEED AHEAD!"
