I have a plumbing plan and my room tags are not showing in my plumbing plan even though they're selected in visibility settings. They show correctly in the floor plan. I should mention that I'm using the roombook plugin.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Have you checked your filters? Your View Template? Is everything on the right Workset? Just some basics that may be creating the problem.
Hi @Anonymous
One possibility: did you create the view with the tags then they disappeared...or you didn't create the plumbing layout view with tags? And how about if u retag them
Second Possibility: did u change the phase? And if you did; how about you re-tag them!
I did create the view with tags and switched discipline to "plumbing" - that's when they disappeared. Did I do something wrong there? I was able to quickly re-tag all rooms. Thx.
