Hi all,
I have to prepare Tile cutting drawings (Bathrooms, Cleaning rooms ...)
I have a Linked Plumbing model with proper position and dimensions of Plumbing Fixtures.
I want to show the Plumbing Fixtures in BLACK color (In linked model are after Plumbing System colorID)
NB I ahve tried already to assign BLACK color to Plumbing fixture in Revit link VG. Not working. Same for Filters.
Any Idea?
Gelöst! Gehe zur Lösung
Gelöst von lucdoucet_msdl. Gehe zur Lösung
When you talk about plumbing system colours then filters not working, so you mean this technique doesn’t work?
Linked File Revit MEP has Colors
https://revitoped.blogspot.com/2015/04/linked-file-revit-mep-has-colors.html?m=1
As I understand Revit graphic overrides, a revit family override does not supercede a mechanical systems color assignment. You need to override the system color assignment with your filter.
-luc
I would check the linked file to see if the Plumbing fixtures in there do have nested families which are a different category.
What is the result when your linked files are 'selectable' and you select the plumbing fixture with <Tab>
What properties show?
Here is an explaination video
I agree with @lucdoucet_msdl,
This most probably is a filter which depends on the system abbreviation.
Do you have any other views where the piping shows? What color are they?
Is there a view filter active.
Easiest way to check is to open the linked file in an extra Revit session so it does not unload from your current project.
