Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Plumbing Calculations Schedule
17 REPLIES 17
Message 1 of 18
aishwaryagNEDYQ
988 Views, 17 Replies
Hi. I am working on a project that has A-2 assembly and B and I want them in the same schedule using an area plan. I am using the formula for B group that is also being used for A-2 which is not right. I have attached a screenshot for you to guide me on how to go about it.
FYI: Not all calculations are right. I am trying to figure out how it would work for one first.
17 REPLIES 17
Message 2 of 18
Where is "Required Male WC" being used in Schedule?  Which column?  Maybe it would be better to just post the file for us to analyze.
Message 3 of 18
"Required Male WC"would be used for Water closets "male" - the value that shows 5.50 for Business and 3.58 for A-2
Message 4 of 18
Okay, whatever. Just make it easy for us to help you. Post your file.
Message 5 of 18
Got the solution
Message 6 of 18
Posted a link for you
Message 7 of 18
in reply to: aishwaryagNEDYQ
You would need to introduce another Integer or Y/N parameter to distinguish A2 and B, and use it as a conditional factor to create a nested formula.
If this formula is for B:
if((OCCUPANCY LOAD < 50), ([Occupant Breakdown(Male)] / 75), (2 + ([Occupant Breakdown(Male)] - 50) / 50))
what is the formula for A-2?
Message 8 of 18
aishwaryagNEDYQ
in reply to: ToanDN
Thank you. The formula has to be "Occupant Breakdown(Male)/75". Currently, both the assemblies are taking the same formula.
Message 9 of 18
So for group A-2, is the formula always Occupant Breakdown(Male)/75 regardless of the load, no threshold at 50 like group B?
Message 10 of 18
aishwaryagNEDYQ
in reply to: ToanDN
No threshold for A-2
Message 11 of 18
if(B, (if((OCCUPANCY LOAD < 50), ([Occupant Breakdown(Male)] / 75), (([Occupant Breakdown(Male)] - 50) / 80) + 2)), [Occupant Breakdown(Male)] / 75)
Message 12 of 18
aishwaryagNEDYQ
in reply to: ToanDN
Can you please share the file with me?
Message 13 of 18
Too big to post.
You can simply add a Y/N parameter, tick teh box for B row, untick for A-2 row.  Then edit the formula, for example for Required male WC:
Do it for all other columns that you need.
Message 14 of 18
aishwaryagNEDYQ
in reply to: ToanDN
Thank you! Let me check if that works for me.
Message 15 of 18
For LAV:
if(B, (if((OCCUPANCY LOAD < 80), ([Occupant Breakdown(Male)] / 40), (([Occupant Breakdown(Male)] - 80) / 80) + 2)), [Occupant Breakdown(Male)] / 200)
Message 16 of 18
aishwaryagNEDYQ
in reply to: ToanDN
For LAV, the final value per normal calculations must be "3.88" but Revit is calculating as "5.76" which is wrong.
Message 17 of 18
I can see why.  You have the schedule unitemized so it gives the false reception of one big area for each group but in fact they are many individual rooms.  Your formula wants to work with a lump sump area, not multiple areas.  I don't have a solution at the moment, need to think a bit more.
Message 18 of 18
3rez
in reply to: ToanDN
@ToanDN Was there a solution to handle the multiple areas calculating incorrectly instead of the sum of the area type occupants?
