Plugins Remove
Plugins Remove
ana.delgadonieto
Plugins Remove
ana.delgadonieto
Hi
I would like to remove a Plugin from the Program Revit
How can IRemove Plugins.JPG do it?
RDAOU
You can check the following link on Autodesk Knowledge Network Disable Add-ins  also note that some user specific add-ins are also located in the %UserProfile%\AppData\Roaming\Autodesk\Revit\Addins\
Deleting the .addin and the associated .dll should basically do it for you
ana.delgadonieto
Thanks for the answer.
I have the file Autodesk in two sites of my computer.  One in Programme/Autodesk and other one in Programme(x86).
What is the different between C/Programme and C/Programme(X86) and why Autodesk has been installed im both sites? Could I could rid of one of the Autodesk filesSystem 1.JPGSystem 2.JPGSystem 3.JPG?
BIMmethods
That's TYPICAL Autodesk and those are not the only locations… Not sure what their software roots itself deep into so many locations but that's how it is and that's why its a pain to clean uninstall an Autodesk product!
On whether you can get rid of one of these folders...No you can't and please don't lol!
Keep Smiling
Hello.
If the installer for this plugin isn't donne by Autodesk the placement of the plugins' files will be very hard to find.
Nonetheless you can erase the correspondent *.addin fil in  C:\ProgramData\Autodesk\Revit\Addins\2019
it wont uninstall the plugin but it will no longer be added to your Revit.
If my answer solves your problem please accept it as answer.
ana.delgadonieto
Thank you all
You Best option is to go to Control Panel\Programs\Programs and Features and uninstall it from there.
