PLUG-IN FOR: WALL METAL STUD FRAMING
12 ANTWORTEN 12
Nachricht 1 von 13
5834 Aufrufe, 12 Antworten
I have install revit 2017, My question how i can draw metal stud wall. If necessary to load revit 2017 extension, then please give the link.
12 ANTWORTEN 12
Nachricht 2 von 13
Sahay_R
als Antwort auf: Anonymous
Create a Revit wall type.
Select a wall
Edit the wall structure. Click Insert to add layers. Use the Up and Down buttons to move them.
Remember - the studs will be Structure, all other layers will be chosen from the list below
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 13
als Antwort auf: Sahay_R
No no my question is different, I have an architectural model in partition wall i want to placing metal stud from structure---wall--curtain wall--metal stud wall. But in this operation we need the REVIT 2017 Extension ad-ons . Do you have this ad-ons. So i can place metal stud consecutively in a distance of 24".
Nachricht 4 von 13
Are you producing light steel framing shop drawings or something?
http://strucsoftsolutions.com/products/
Nachricht 5 von 13
als Antwort auf: ToanDN
No no i do not create shop drawing. I have an architectural model where i want to placing metal stud in partition wall.
Nachricht 6 von 13
but you have send me a link kindly brief about that it may be solve my problem
Nachricht 7 von 13
If you are loaded with money then you can try the link above. If you are cheap like me then use curtain wall mullions to build those. Although I am just now realizing that I am not only cheap but also lazy because I never came up with the idea of model light gauge metal frames in any projects that I have worked on. Why do you do it?
Nachricht 8 von 13
I never use the product in the link but from a quick glance, it does what you want. You can go to the link and read what they do in more details.
Nachricht 9 von 13
Sahay_R
@ToanDN @Anonymous - never seen anyone model metal wall studs at all. Wonder why you would want to do so - I think this would add unnecessary geometry and complexity to the Revit model.
Rina Sahay
Nachricht 10 von 13
chrisplyler
I've never had a good reason to model any secondary framing. But I've often WANTED to. Because it looks cool.
Nachricht 11 von 13
it's demanding our client. They want that remove layering wall and place metal stud into the partition wall where both side are gypsum board are already fixed.
Nachricht 12 von 13
chrisplyler
Solution:
Explaining your client why this is not standard practice. Giving your client very high pricing for compliance with their demanding. Problem go away.
Nachricht 13 von 13
als Antwort auf: chrisplyler
@chrisplyler wrote:
Solution:
No kidding.  I suspect when they see new pricing the "very important" item suddenly will not be very important anymore.
