You may consider using structural framing, and creating framing elevations to adjust and modify the set out to suit. You'll need to use both Columns and beams to get a full wall if you require studs, braces, struts and dwangs (noggins or perlins). Using framing you can set stud type, automatic spacing Similar to Curtain wall function. Using framing you don't need to exclude panels. and Revit knows this is framing for scheduling.
Curtain wall will give you a solution and depending on the LOD may be adequate.
Hope this helps
