Plotting Structural Plan with Vector vs Raster mode
0 ANTWORTEN 0
Nachricht 1 von 1
julia_cheong
96 Aufrufe, 0 Antworten
Hello, I hope you are all having a great time with your projects!
I need someone's troubleshooting guide for the plotting process of a structural plan.
I have tried a couple of methods: plotting with Vector/Greyscale mode and Raster/Greyscale mode.
The problem with the vector mode is that the hatch display is not greyscaled when I print it on paper (it looks okay in PDF mode). The hatches are in black mode, so they overlap with the text.
On the other hand, in raster mode, it appears as I want it to, but when I export it to PDF, the resolution is very low and all the lines are unpixelated, except for the text.
I have considered using both methods depending on the situation, but I would prefer to use only one setting, similar to CTB in AutoCAD.
Could someone provide me with the best solution to plot the plans both on paper and in PDF?(Revit Version: 2024)
Thank you.
Sincerely,
Julia
Raster/Greyscale
Vector/Greyscale
0 ANTWORTEN 0
