Plotting from Revit to Bluebeam PDF leaves text garbled, mishaped
2 ANTWORTEN 2
Nachricht 1 von 3
RedMan77
157 Aufrufe, 2 Antworten
I've seen several posts about this where plotting to PDF leaves text garbled. The posts I have seen refer to Adobe Acrobat but little when it comes to BB. I've seen everything from uninstalling KB updates to reinstalling .NET updates but this is an issue that seems to have sprung up very recently.  Unfortunately, this is a 2021 project, but little has improved with 2023. With 2023 it does improve slightly by bypassing the BB print driver and going straight to export. Can someone please shed some light why this garbled effect is happening. Improving dpi has very little effect. Thanks in advance
2 ANTWORTEN 2
Nachricht 2 von 3
Mike.FORM
als Antwort auf: RedMan77
You could try to deleting the Revu Font Cache xml file in C:\ProgramData\Bluebeam Software\Bluebeam Revu\21\Revu
Restart Revu after to see if that fixes it.
Is the font you are using a standard windows font? Is any of that font coming in from AutoCAD?
Nachricht 3 von 3
RedMan77
als Antwort auf: Mike.FORM
Its using a truetype font called A. Ember not directly from Autodesk and not a standard font. Will try your suggestion and get back to you. Thanks.
