Recently our firm lost the ability to print to our plotter from Revit 2017. We can print to pdf and print to the plotter as well as print directly from revit 2016. Any thoughts? We cannot even get it to preview, the window just closes and if you click print it does the same thing and never sends anything to our plotter.
Hi @Anonymous,
Please have a look at THIS POST as this is a general problem for some users. This post will provide you with possible workarounds for now.
I've been using PDF Creator since this problem started to surface without any issues, other users also prefer or reverted to using Cute PDF to create files.
I hope this helps! ![]()
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
I have no issues creating pdf, I use cutepdf writer. It is just my 24" HP plotter. And only on revit 2017 directly.
Hi @Anonymous,
Apologies
I was busy reading through a different thread where the issue was relating to PDF issues in Revit 2017.
I can unfortunately not test a couple of things as we use OCE plotters, but what you could try is:
(I'm assuming that you're on Windows 10?)
Revert to an earlier plotter driver. I know there came a load of issues relating to Revit and the Windows 10 anniversary updates. You can read up on how to do this HERE
In THIS POST you'll notice that there are also other people struggling with the same issue.
I hope this helps!
Rudi Roux
LinkedIn
