Hello all
I wonder if you can help me?
I've created a custom beam family in Revit and loaded it into my project. It looks great when I view it in 3D mode but in Section it is just showing as a dot.
Any ideas where i've gone wrong? (pics attached)
Thank you
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Let me add to PijPiwo's reply: if you want to show the member geometry to show up in Course Detail View, then in the family select the geometry and go to Visibility Settings and check the Course box. If you go this route, you might as well delete the Stick Symbol too.
