Plans not in level order when exporting to DWG from Revit - Problem
2 ANTWORTEN 2
Nachricht 1 von 3
sh_arc_moshe
176 Aufrufe, 2 Antworten
Hi all,
After exporting a revit sheet with multiple level plans to a DWG they appear in the DWG in a random order every time. and not in the order that they are in the sheet or as the order of levels.
This issue takes extra efforts to re-arange the DWG to it's level order every time.
Any help or advice woud be helpful.
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: sh_arc_moshe
Export each plan individually and name the DWG files to reflect the correct order.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
handjonathan
Hi @sh_arc_moshe
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
