Plans going to wrong category
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
Sahay_R
459 Aufrufe, 6 Antworten
When I create a plan view from levels added to an elevation, it goes to the wrong category which makes searching for them in the browser a challenge. I know it's an easy fix - we just have to switch over to the correct template - but it's annoying all the same. I hope that someone can solve this!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Sahay_R
You can change the template while creating a new view.
Nachricht 3 von 7
Sahay_R
als Antwort auf: ToanDN
True. That's the one extra step we want to avoid.
Rina Sahay
Nachricht 4 von 7
alan.quinn
As ToanDN pointed out, if you change your Template (the first time) and choose the Category you want it will retain that setting. Each new Plan View you create will be placed in the Category you picked.
Hope this helps and thanks for posting.
Nachricht 5 von 7
Sahay_R
als Antwort auf: alan.quinn
Perfect! Toan and Alan - thank you!
Rina Sahay
Nachricht 6 von 7
chrisplyler
If you want your template file to already have the correct setting, open the template file, change the setting, then re-save it as a template again.
Nachricht 7 von 7
Sahay_R
als Antwort auf: chrisplyler
Done!
Thank you, Chris!
Rina Sahay
