Nachricht 1 von 6
jfjacques
293 Aufrufe, 5 Antworten
Planes
Any way to set workplane without having ot go to the menu. Perhaps setting pick by face by default?
If I set the work plane I have to go to the work plane menu first, and click on the set by face button. It's a little thing but sometimes it's a nonstop pain of an additional step. In any case.  Possible?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jfjacques
Shorten the "process" by creating a keyboard shortcut.
Nachricht 3 von 6
jfjacques
als Antwort auf: barthbradley
I have shortcuts for everything.  Is it possible to set key for set on face?
Nachricht 4 von 6
ennujozlagam
i don't think its possible you need to pick the planes. thanks
Nachricht 5 von 6
jfjacques
als Antwort auf: ennujozlagam
I don't mind picking the plane. I want to skip the window which asks me what to pick.
Nachricht 6 von 6
Just FWIW, sometimes you don't need to pre-select the Work Plane. They are all available (named ones) to choose from in a drop-down on the Options Bar when placing certain elements. Beyond that, I don't know how you get around the Set Work Plane dialog box, unless you can figure out a way to hard-wire Revit to your brain.
