PLAN VIEWS
3 ANTWORTEN 3
Nachricht 1 von 4
257 Aufrufe, 3 Antworten
PLAN VIEWS
My plan view seems very strange ! i extrude two casework component in my project , place in two diferent position , in the 1st floor plan i can see both item , they are completely fine , but in second floor i can see only one , the other is dissapeared even it's still appear in other floor plan , i check view range , hidden item , visibility but not things work , help : (((
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello , can you post your extude casework so we can check. thanks
Nachricht 3 von 4
Is it showing in 3d?
Nachricht 4 von 4
FGPerraudin
Hi ThaiThan,
Have you ckecked your 3D item?
Just right click on the casework, and in the Modify panel of the ribbon, go to  View > Selection Box (BX).
This way you will be able to easily check your 3D casework.
It is probably just one extrusion not placed the same way as the other one... (extrusion height, general altitude, ...)
Tell me if it helped,
François
Francois-Gabriel Perraudin
BIM management and coaching
