Is there a way to turn off a plan region not just hide the lines.... i.e. where it would be completely invisible in certain views? In other words, you could show a clerestory of windows on a floor plan.... but not see the windows in the roof plan...
Is there a way to completely turn off a plan region? i.e. see clerestory windows in a floor plan.... Not see it at all in a roof plan?
Perhaps you can use an Underlay of an upper / clerestory Level in the Floor Plan to see the Clerestory--to achieve this?
Just delete it!
Hi
Plan regions are view specific..so if you don't need certain plan region then just delete it..
Even after that if windows are showing up on Roof Plan, then you need to fix
the underlay, View range.
this should fix it, else you will have to look into Windows family for the graphics..
Cheers!
