Plan Alignment
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
tstewart
454 Aufrufe, 6 Antworten
Plan Alignment
The Plans and Gridlines are not aligned, so how to align them (3rd Request)?
6 ANTWORTEN 6
Nachricht 2 von 7
rxi.gg
als Antwort auf: tstewart
Rotate the model?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 7
tstewart
als Antwort auf: rxi.gg
The model (Floor plans) needs to be aligned w/ Grid, so how can I align them?
Nachricht 4 von 7
rxi.gg
I think the easiest way is to rotate the project north and rotate the grids then
Nachricht 5 von 7
tstewart
How to do these tasks?
Nachricht 6 von 7
rxi.gg
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Then rotate the grids, with the rotate tool.
Nachricht 7 von 7
tstewart
Thank you.
