Hi, regarding revit 2018
I am bulding up a walk-in structure as in picture.
In order to make it monolithical, and to get opportunity to reshape the form later, I used roof by extrusion tool.
I need to place door on the vertical sides, but as supposed, roof can't host doors.
Any trick?
thanks in advance
christian
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
A "vertical roof" can be considered a Wall--so, use a wall to host the doors/windows. The wall can have the same materials as the roof as required.
You can make a Door Family or Window Family to be placed on Roof.
For this :
Constantin Stroescu
anyway...these Door/Windows do not work for vertical Roofs....so, perhaps the ToanDN suggestion of using identical layered Wall and Roofs and join them together seems to be the right one.
Constantin Stroescu
As I mentioned in post #2 above...……………..
Pardon me for my mistake....yes , as you , also , said in post 2.
Constantin
Constantin Stroescu
