Placing a family by Shared coordinates
6 ANTWORTEN 6
Nachricht 1 von 7
1161 Aufrufe, 6 Antworten
Hello
I need to place a family into a project.  It has the coordinates within it, but that doesn't help if I need to actually click somewhere to place it.  How can I place this family when I don't have anything to click on to place it?  There is also nothing legitimate to align to.  The model is mostly links and I cannot align to them.
Nardo
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Use shared coordinates. It references the project's base point, not ref. planes. Should drop right into place if set up correctly.
Nachricht 3 von 7
als Antwort auf: barthbradley
How does one "Use shared coordinates" to place a family file in a normal Revit file?
Nachricht 4 von 7
I am not aware of Shared Coordinates in Families (RFA).  What sort of family is it?  Can you share it?
Nachricht 5 von 7
You don't. Sorry, I didn't notice "Family". You can take back your Kudo, if you like. HA!
There is a way to do it, but it's not a conventional approach. Not sure you really want to hear about it.
Nachricht 6 von 7
als Antwort auf: ToanDN
I am receiving pieces of a Rhino Model that have good shared coordinates.  I cannot put them directly into a in-place family because these pieces make the model too slow for a central file that will slow things down for everyone.  So I need to be able to bring it in at the last minute.  It will need edited as the project progresses.  So it must remain separate.
I made a separate Revit Model that I have linked in.  That model hasn't been exporting properly to the various formats that I need to be exporting to.  So I am trying it as a large family.  I hope that things will work more smoothly.  Maybe not but I need to give it a try.
Can It be place from the Families area of the project browser, once it is in the project?
Nardo
Nachricht 7 von 7
Per this previous post; how do the materials hold up with this process that you propose?
