Placement of Adaptive Families
2 ANTWORTEN 2
Nachricht 1 von 3
enji.sorial
453 Aufrufe, 2 Antworten
In the attached file, there are adaptive panels placed and I can't find the host. Does that mean, it is done using Dynamo? If so, how can I regenerate the script used to place the adaptive components?
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: enji.sorial
Did you place all these Adaptive Panels one at a time?  Why not create it as a Curtain Panel Pattern-Based Family and assign to a Divided Surface? That would be a whole easier.
...I believe the host was originally a Divided Surface. It's gone.
Nachricht 3 von 3
enji.sorial
als Antwort auf: barthbradley
I tried before with a divided surface, but it didn't turn out well. The form is made of 3 curves, so when you divide the surface, it is divided into 3 separate parts, so you have to adjust where the pattern start and end on each surface plus that the panels at the connection are deformed somehow as shown in the attached example. Actually I need to change the level on which the panels are hosted and was asking if this was made using Dynamo?
