Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Place Steel profiles on curved Edge
31 REPLIES 31
Message 1 of 32
khalili_masoomeh
1550 Views, 31 Replies
Hello every one.
 is there anybody who knows how I can place a profile (Steel Profiles for example a rectangular Box) on a curved edge like what i showed in the image. if anybody also knows a way to solve it by Dynamo it would be fine.
thanks in advance
31 REPLIES 31
Message 21 of 32
You can add as many parameters to families as you want, in-place or otherwise... then just dimension the length and return it in a (shared/scheduleable) parameter. edit: That's actually not as easy as I thought in this case, probably you will need Dynamo to do this.
Message 22 of 32
Actually you could add up the segment lengths manually and input them in a (locked) parameter as defined length perhaps, but probably Dynamo is a better option for that depending on how many you would need to do. Another option could be to divide computated volume with the profile's area.
Message 23 of 32
thanks a lot for your kind reply.
I 'm looking for a way to display the length of the profile when we go to Schedule . Is it Possible for in - places ?
Message 24 of 32
So this is all about reporting the length of the edge profile? I can think of a few approaches. What exactly are you modeling anyways? Can you post some pictures? How about your Revit File?
Message 25 of 32
You can add parameters for in-place models while in edit mode same as in family editor. Also for material etc. Modify and open Family types under properties tab.
@barthbradleyThe .rvt can be found in post#10 as .rar file.
Message 26 of 32
thank you. yes i see we can create any parameters but how you make it read the shapes Length for example. the material is ok but when we create a new Parameter as Length its value is 0 . how we can make it read the in -place's length. is it possible ?
Message 27 of 32
Thank you @martijn_pater
@khalili_masoomeh: can you post the RVT? Unable to open RAR.
Message 28 of 32
in reply to: khalili_masoomeh
Here is a brief attempt.  I only placed a few profiles along the edge so the sweep doesn't match the host perfectly.  More profiles would give a better result.
Message 29 of 32
in reply to: ToanDN
@ToanDN: Is this the OP's base construct? The Basic Wall?
If so, I can't imagine how you Revit could extract and Schedule ANY linear measurement from that shape or yours.  Even if it could, what would be the construction value of those linear measurements?  I can't think of any.
Just fielding the question...
Message 30 of 32
in reply to: barthbradley
It can. I just did not do it for that model. Hint: reporting parameter based on length of divided spline.
Or, a calculated parameter: Gross volume / profile area (known).
Whether it is useful or not, I can't answer.
Message 31 of 32
vick1z
Please look at this past post might help, Screencast done by  Toan. Thanks Toan
https://forums.autodesk.com/t5/revit-architecture-forum/purlins-on-curved-beams/td-p/7375485
Message 32 of 32
khalili_masoomeh
in reply to: vick1z
thank you all for your kind helps: @vick1z  @ToanDN  @barthbradley  @martijn_pater  @hmunsell
