Place on stair railing tool
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
ChrisGamble
952 Aufrufe, 5 Antworten
How do I edit the place on stair railings tool settings to not put a railing at the entrances of my stair?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: ChrisGamble
Edit sketch, get rid of half of the railing, finish. Place another railing, edit sketch, and get rid of the other half.
Nachricht 3 von 6
ChrisGamble
als Antwort auf: ToanDN
That makes sense but that's kind of too complicated because the stair path is overlapping, so once I finish the sketch, revit doesn't like what I did and gives continuous stair and overlapping error messages.
Nachricht 4 von 6
cbcarch
Make the Landings Floors, then create new railings and host to the floors, not stairs. This way you have individual control over them.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 5 von 6
ChrisGamble
als Antwort auf: cbcarch
Worked like a charm.
Nachricht 6 von 6
ChrisGamble
Also FYI to anyone reading this, you also cant use the place on stair/railing tool if one side of your stair has a railing already. It has to do both sides at the same time. It wont place a railing inside a railing.
