Place a group in a split view
8 ANTWORTEN 8
Nachricht 1 von 9
Darwin33
510 Aufrufe, 8 Antworten
I need to insert some groups in an split view.
But unfortunately I can no do it. I only can place the group in an non split view. Is there any solution to this.
Thank you very much
8 ANTWORTEN 8
Nachricht 2 von 9
kostask_oionei
als Antwort auf: Darwin33
What do you mean by split view?
If you mean cropped view or dependent, of course, and you can also place model and detail groups.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 3 von 9
Darwin33
als Antwort auf: kostask_oionei
Yes I say in a crop view, but I cant unless I make the view unique, otherwise I have a warning window, saying that is out of the view range...
Nachricht 4 von 9
kostask_oionei
Can you share a screenshot or something?
Kostas Kouris
Nachricht 5 von 9
Duplicate the view, uncrop and place the model group. It will show in the splitted view.
Nachricht 6 von 9
Darwin33
als Antwort auf: ToanDN
-it is a 2d group.
I can not place a screen shot, because I am woriking with the German language. Nevertheless the message says that the group is out of the scope of view. If I uncrop the view then it works , but obviusly it is not an option because I need the cropped view.
Nachricht 7 von 9
kostask_oionei
I asked for a screenshot to see where is the group origin.
Maybe it is out of the crop.
If yes place the group in a non cropped view, move the group origin and try again.
Then you can move the origin back.
Kostas Kouris
Nachricht 8 von 9
@Darwin33 wrote:
-it is a 2d group.
- Duplicate the view as dependent
- Uncrop the dependent view
- Place the detail group in the uncropped dependent view and it will show in the cropped/splitted view
Nachricht 9 von 9
Darwin33
HAllo,
I ve found a solution. You have to placed with the option, in the same place place. If you try to place in a specific place then it doesnt work, but if you place it in same location place, then you can move it.
