Pixelated / shaky lines
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
2130 Aufrufe, 6 Antworten
Hey everyone,
I Installed Revit on my desktop and the lines look Pixelated/shaky on the display, ant not as crisp as on my Laptop.
also, when I export a sheet to PDF the lines are super thick.
I tried changing thorough the display options to Revit working on the NVIDIA graphic card, and Tried pressing TL in Revit but it didn't work.
Any suggestions would be helpful! thank you!
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: Anonymous
have you try to check in your options setting here?.thanks
Nachricht 3 von 7
als Antwort auf: ennujozlagam
Yes,  I checked, those are my settings.
Its still  looks pixelated
Nachricht 4 von 7
a new finding -
When I change my laptop resolution to 1920X1080 it also looks awful, so I guess that's ok that the display looks like that.
But why is my exported PDF looks bad as well? even if I open it on a high resolution screen!
Nachricht 5 von 7
syman2000
Upload the PDF file and see if we get different result. What is your desktop monitor spec compare to your laptop spec? If you have old desktop monitor (Non 4k), the pixel density is not as great as the newer laptop screen.
Nachricht 6 von 7
TripleM-Dev.net
There was another Thread solved last week also about a graphics issue, now you mention screen resolution.
https://forums.autodesk.com/t5/revit-architecture-forum/all-elements-showing-as-halftone/m-p/9984445...
Maybe it helps?
- Michel
Nachricht 7 von 7
Its probably my monitor. Thank you!
