Pixelated interior rendering - Revit 2017
3 REPLIES 3
mpednaultGXFA2
1466 Views, 3 Replies
I've rerun this interior rendering on the cloud multiple times without any luck.  It keeps coming out pixelated.  The other two renderings of the same Revit model and using the same View Template settings are perfect.  Any help would be greatly appreciated.
3 REPLIES 3
Render is noisey/grainy. Solution= More light. More time.
Figured it out.  Before I sent it up to the cloud, I needed to go into the Render tool within Revit and change the lighting to interior artificial only.  I had already done that on the other two.  This isn't an obvious setting because the "Render to Cloud" tool doesn't bring it up and it's not listed in the view template either.  Got it fixed though and looks good.  Thanks!
More Light=Less Graininess. Exactly what I suggested. Thanks for sharing.
Rail Community
