I have a linked Mechanical model that isn't behaving how it should. At least how I think it should.
There's some small sections of vert pipe that are showing up all over my ceiling plans.
When I look at the Pipe in a 3d view, it's not touching the ceiling. The ceiling is hiding all of the horizontal runs that are above the ceiling.
The insulation on the pipe that's causing the problem isn't showing up. Just the pipe.
I've looked at most of the VG options. The ceiling is visible. It's not transparent. The material isn't glass. Discipline is set to Arch.
See Attached.
Any Thoughts?
