Hallo Everyone.
Can someone please tell me how can i trim the the pipe at different angles in section and in view. The picture is in attachment.
The yellow line shows where i want to cut the pipe
Gelöst! Gehe zur Lösung
Gelöst von mauricio_mssf. Gehe zur Lösung
Revit won't do that to pipes. A masking region might get you what you want.
Just like @RobDraw said, this cannot be done, so as not to disturb your material count
But if counting is not a problem, I saw once that people made in pipe fittings family a parameter to control the angle and linked it to a void, so that the cut could be represented, and they just filtered this pipe fittings from the table . but for me it still takes a few centimeters from the size of the pipe.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
You could stop the pipe short and put a void in the angled wall or what ever it is that the pipe is going thru.
Howard Munsell
