Pin Objects Not Working
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1868 Aufrufe, 3 Antworten
has anyone ever had the problem of pinning an object and then not being able to unpin it? Every time I pin an object, it will not let me select it to unpin it. Never had this happen before. I'm currently still in Revit 2018.
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: Anonymous
Check if "Select Pinned Objects" is turned off in lower right corner of screen. Look for the "Pin" shaped icon.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
als Antwort auf: cbcarch
That is what it was! Thank you for your help!!
Nachricht 4 von 4
deanmaher
Thank you very much for that tip.  I had the same issue for the last week & couldn't figure out how to fix it.
