is there a way that you can lock a object in revit so that it wont be selected like autocad?
And is there a way isolate the group of items that i selected so that i can only modify that group of items like autocad?
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Usually I would use this button at the bottom right corner. If you click on it, any pin item will be unselectable. When you click on it again, you can select them.
For isolation, you can select the object and then Isolate element or category. Once you finish what you are doing, you can reset temporary hide/isolate objects
I'll use a Selection Set first, then Pin and Temporary Hide/Isolate:
Constantin Stroescu
