Announcements
Pin and Unpin grayed out
ritztran
ritztran
This is my situation. I want to remove the stall, but could not because both pin and unpin feature grayed out. I know it is a part of a group, however, I don't see the group modify panel appear when select it. Can someone explain and inform me what I missed? Thank you in advance.
You are selecting a Parking Site family, just press DEL to delete it.
Kimtaurus
How did you select that element? By cycling through the elements with the tab key? If it's really part of a group, you need to edit the group first. By default, simply  selecting an element in a group, selects the group. Unless ofcourse you select after using the tab-key.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Corsten.Au
Hi ..
you have to first select the " group"..
isolate that group..
and then edit that group..
selecting one element of the group is going to show you " group edit " option...
Cheers
Corsten
Building Designer
ritztran
Yea. I think it was my fault not selecting the group first. I select the parking stall by pressing the tab key, so I couldn't finish the delete command. I figured it out when I selected the group and delete it in edit group mode.
Thank you all for your comments. I appreciate it a lot.
