pictures don't appear on render in cloud
2 ANTWORTEN 2
Nachricht 1 von 3
11142696
269 Aufrufe, 2 Antworten
this pic before render
1231213.pngthis pic after render on cloud (no pic)
2 ANTWORTEN 2
Nachricht 2 von 3
cbcarch
als Antwort auf: 11142696
Those are most likely Decals, which use an image file to render in the view. When rendering in the Cloud, make sure each Decal has a separate/individual image file attached to it. -File names are a bit finicky when cloud rendering also. -Check the file name of the image that doesn't render in the cloud. Try renaming with all lower case letters, save, re-apply the Decal, Synch to Central, then Render in Cloud.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 3
11142696
als Antwort auf: cbcarch
this pop-up appears (render on cloude )
[cid:5aecdee1-3a27-44f0-ae61-d493d2fce49d]
